mjmedlo:
I have been informed that to use the BS5 as Audio Master NO you must you an active kit in the same room.
I.E. I want the BS5 in a link room with speakers connected to it. The main room has a BS9k and a BV9 (the audio and video masters)
So, apparently I must use an active kit on the ML network in the link room with the BS5 so I can hear music from it in the link room as well as distribute the music from it to the rest of the house. .
thoughts?
While this sounds weired, I think this is correct. I have a BS9K + BS5 in one room and BV8 in another. I tried moving the speakers from the BS9K to the BS5, and I couldn't get it to work locally - I could call up N.Music from another link room, but the BS5 did not drive the attached speakers. This leads me to believe that the BS5 only drives connected speakers if Audio Master ON. It could also mean my speakerless BS9K is gumming up the works (but I didn't really have time to do a detailed test). Also, as mentioned above, even with the BS9K connected properly, if I turn on the BS5 directly (via the button on the back of the display), my TV goes to N.Music mode. This would make sense if they were in the same room, but they're not (but I don't see any way to tell it this). Probably not what you want... hence, add an active to the room and then you can access all sources and the BS5 will distribute sound... I don't know what B&O charge, but you can often find BL Actives on auction sites for ~$100 (I bought one once without any problems).
Stan
