Latest post 01-14-2011 8:42 AM by kallasr. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 07-31-2010 2:12 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: BS2 Speaker Setup
    Here we go....
    Just same cables to be hidden Hmm
    Best regards
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-01-2010 12:57 AM In reply to
    looks great ... but won't you get a stiff neck from looking sideways ?
    just joking ... I wish I had a setup like that :)
    love those BeoLabs !!!
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-14-2011 8:42 AM In reply to
    • kallasr
    • Posts 1,077
    I want to upgrade the panel and found a panasonic TH-42PH20.
    What values do I need to change in the menu of the panasonic to make the beosystem 2 see it as an Beovision 4 panel???
    Any hints?
    for D6/D7 panels I found the information, but no idea about the one mentioned above...
    Ralf
