Latest post 05-20-2010 9:23 AM by Razlaw. 54 replies.
Page 3 of 3 (55 items) < Previous 1 2 3
  • 05-20-2010 2:44 AM In reply to
    Re: AST Help & Understanding
    tkl95:
    On topic 4, I have indeed a very symmetrical setup in a 6x5m room.
    In that case, AST would probably be of no benefit to you. It's a solution to a problem - but you do not have that problem... :-)
    Cheers
    -geoff
    Filed under:
  • 05-20-2010 2:59 AM In reply to
    Razlaw:
    Thank you very very much.  I am still confused about a couple of issues.
    When in the set up menu and measuring all of the points from point A and B, one of the points measured to is viewing position. What is that position and how does it relate to the positions used with the presets obtained using the three speakers?
    Also, as for setting the rotation, is the merely a matter of taste as to which direction one prefers the sound to be coming from while listening from a specific preset location?
    This is a little more difficult to explain...
    When you put in the distances from the speakers to points A and B, the system triangulates and converts the measurements into an X-Y location in space for each loudspeaker. (See the figure below...)
    However, there is a problem. If we just get those two distances, we don't know which side of the wall you're on... See the figure below as an illustration.
    So, how can we find out whether you're in the LEFT universe or the RIGHT universe? This is where the TV Left, TV Right and Viewing Position measurements are used. By asking for these three, we can make the decision... See the figure below.
    Notice that, on the LEFT side of the wall, the position that should be TV Left is on the right of the viewer. Therefore it's wrong... so we now know which side of the wall you're on.
    Essentially, this is the only reason for putting in a Viewing Position. The TV L and TV R are used to remember where the television is (for the default rotation of 0 degrees in the presets).
    Remember that the Viewing Position is not used for any of the listening presets - you have to have a Listening Position for those. However, the Listening Position and the Viewing Position could be in the same place.
    To answer your second question - yes. Your rotation is simply a matter of taste. Personally, I ignore the display and set the rotation by ear.
    Hope this helps.
    Cheers
    -geoff
    Filed under:
  • 05-20-2010 8:34 AM In reply to
    Thank you very much. Makes complete sense now that I understand the viewing position is merely a measuring point that can be the same as a listening preset, but does not have to be. It is just a point chosen at random within the viewing field so that the system knows which side everything is on. Thank you again!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 05-20-2010 8:38 AM In reply to
    Almost at random... make sure that you can view the TV screen from the viewing position.... Apart from that, it really doesn't matter where it is. :-)
     Cheers
    -geoff
    Filed under:
  • 05-20-2010 9:23 AM In reply to
    Thanks!
