thavn:
Mine has been delayed too. It will be delivered at my house the 11. or 12. of Desember. In time before Christmas anyway!
One question:
The TV is designed to hang on a wall, and my wife is very keen on wall mounting. However, what height is recommended? It looks better on the wall when it is in line with other paintings, but then the picture will be too high when you are watching TV. My B&O dealer recommends 100cm height at the bottom of the picture. Any thoughts about this? I still have a few days to decide...
Personally I don't think that height on the wall is a great issue. There's always been a view that TV's should be more or less at eye level when you are sitting down, and putting an old CRT high up was never an option (except for BV1's on stands!)
If you've got a large room it won't make much difference if you have to raise your eyes a few degrees from horizontal, so if your normally sat at some distance from the screen just put it at a height that looks good alongside your artwork.
If you've got to sit up close then maybe you've got to keep it low (but maybe you shouldn't be going for a 40" screen in that case!
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
