Ah there it is, the Samsung digit problem J
I remember having the same problem as I did the programming for my old Samsung…
Do you have to press a button looking like this -/-- on the original remote to switch from 1 digit to 2 digit input mode?
If so, you have to capture that button as well and add it to your buttons on the Beo5 as the Samsung panels don’t do it like normal TVs do:
Normal TV: If you want to go to channel 13, press 1 and then 3
Samsung TV: press -/-- press 1, press 3 and if you want to switch to 5 for example, press -/-- again…. Welcome to planet Brain-dead J
The Digit section of the Beo5 cannot be changed at the moment (I don’t understand why but you cannot change it…)
Good to see the progress of your programming J
Best
Stephan
