Latest post 08-05-2009 7:31 PM by Evan. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • 08-05-2009 2:54 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: BeoLab 5000 Panel speaker
    tournedos:
    evman140:
    So all I will ultimately be doing is adding a wall plug?
    Yes, I guess Bieele is right and they have been just cut off. Did you get the speakers as a working pair? Over here cutting the power cords is a common (and annoying) practice of marking electrical items in unknown condition...
    You can just splice a new cord with a plug into the old remains, but I personally don't like that solution. Somebody some day might accidentally yank the connection loose, and then you have live wires dangling about.
    ...........Not to mention a fire risk - don't do it. Replace the cable properly.
  • 08-05-2009 3:16 AM In reply to
    Get the power chords replaced.
    If you can't do it yourself then leave it to your local electronic repair shop.
    I have replaced several myself, it's not rocket science and should not cost much.
    Regards Graham
  • 08-05-2009 9:03 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Yea I'm going to do it myself, and I will be repalcaing the entire thing for many obvious reasons.
    I'm not anywhere near them right now so I cant look, are the cord connections just tie ins with screws or soldered?
    Evan
  • 08-05-2009 10:14 AM In reply to
    Soldered.
    Regards Graham
  • 08-05-2009 7:31 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Well all everything is running smoothly, I am very appreciative. Thank you to all who helped gettin my labs going!
    Evan
