Latest post 05-13-2009 6:20 PM by Puncher. 54 replies.
Page 3 of 3 (55 items) < Previous 1 2 3
  • 05-13-2009 4:18 PM In reply to
    Re: advise needed beolab 5
    Your dealer doesn't know the system or equipment, Nisrani, and I can well understand why you are confused.
    If you look at thavn's post above, or kawo's following concerning wrong dealer setup procedures, then you get an idea as to what you should do.
    You want to listen to the BL5s, with the subwoofer signal actually being sent to the BL5s. Look at Kawo's post for the possible problem. The BL2 can be attached, if you want to compare the sub signal of that to the BL5. But it is essential that your dealer goes into the Loudspeaker setup menu and actually disables the Lab 2. If not, the sub signal won't go to the BL5s.
    Show the dealer this thread.
    It's a shame that you should have this much bother in making a decision.
    Cheers!
  • 05-13-2009 4:45 PM In reply to
    tommorow i will go back and try it again
    and i will also go to another dealer
  • 05-13-2009 4:49 PM In reply to
    Puncher:
    nisrani:
    hello
    i went to the same store today because one of the staff members got back from holiday and he could give me the advise about the bl5
    but he said the same thing that i cannot use the bl5 with the bl2
    because it wouldn t get the right signal only if i gave the bl5 another name
    in the set-up menu
    confussed
    I don't think anyone has said that the BL5's should be used with the BL2 - infact quite the reverse.
    If I paraphrase correctly the recommendation was to select the BL5's as fronts and ensure the sub channel is turned off.
    i said it wrong he said to me that the bl5 didnt give so much power as the bl2 for the movie experience
    and that they are better for music so he advised me if i would buy the bl5 and i also would like
    the movie experience i should also by a bl2
  • 05-13-2009 6:14 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    I'd have to disagree - BeoLab 5s deliver far more punch than the BeoLab 2 does in my experience, and are much better for both movies and music (with music being the biggest improvement).
     Weekly top artists:
  • 05-13-2009 6:20 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    nisrani:
    Puncher:
    nisrani:
    hello
    in the set-up menu
    confussed
    It saddens me to say your dealer sounds like (yet another) wallmart reject - my advice, try another dealer!
