The idea is to use as much as possible from the original Avant (or BV3) chasis.
From some experiments with beosystem 2 (mk 1,2 and 3) I know that the software is clever enough to figure out what's connected and behave accordingly. The beosystem 2 (and Beovision 5) are very very very similar to the Avant DVD RF. I assume that if you remove the deflection board it will behave as a beosystem.
If that doesn't work I think it's possible to trick the Avant into working without the high energy boards.
