Hi everyone
Just an update on this project. Using all of the information from this interesting thread, I have spent the last few months working on some of my faulty displays. The following points might be useful to anyone who is thinking of undertaking a similar project.
The 0603 SMD LEDs (14mcd) were easy to get and have worked well. It took me some time to develop a good soldering technique (I have now used 60 LEDs out of my reel of 100) but you do need a good iron and some very fine solder. I also had to make a special shaped holder from a wooden barbeque skewer which keeps the microscopic LEDs in place during the soldering process.
Removing the display from the main PCB was fairly easy but I don’t want to do that too many times for fear of damaging the main board. I purchased the parts that have been listed for the header and socket connections but never installed them for a few reasons. The balance display on the BM8000 has pins which are very long and I thought that the header and socket assembly was too short. Some of the pins are also bent which makes the job more difficult. Finally, I wondered if I would ever be able to get the whole display reassembled because the plastic support only has limited flexibility. Even reassembling the original pins was hard enough. I’ll need to build up more confidence to do that job!
My balance display was suffering from three failures so I decided to replace all 11 LEDs. This task was easy once the display had been dismantled and the small PCB held nicely in a vice. With this job, I learned that any of the existing LEDs that are working can be very easily damaged when the white plastic part is removed. The white plastic has to be lifted off very straight so that it doesn’t hit any of those small wires. The same goes for putting it back in position. On my first attempt, the number of failed LEDs increased from 3 to 5 simply during the dismantling process. Thereafter, I took much greater care during dismantling and re-assembly. Fortunately, the 0603 LEDs are much more robust and will take a lot more knocking – part of the benefit for deciding to replace the lot.
My TP8 display only had one failed LED so for this one, I decided to just replace it with the 0603. I carefully took the display apart and was able to swap the bad LED without damaging any of the existing ones. The only problem was the fact that the new LED is significantly brighter than the older ones.
During the reassembly process, I decided not to glue the red lens cap or the white plastic number mould to the back of the display PCB. These parts have a very snug fit in any case and gluing didn’t seem to be essential. It also means that when the complete display is resoldered back onto the main board, you can remove the lens cap and mould to access any faulty LEDs, without having to unsolder all 18 pins again. This proved to be a useful approach when it became clear that one of my LED solder joints was less than perfect.
Being able to remove the lens cap easily, I then experimented with the problem of the single bright LED. My final solution was to put a small section of photograph negative over the segment, on top of the white plastic and held in place by the lens cap. This very simple solution has resulted in all of the segments in TP8 having a uniform intensity and the results look very good. When I find a larger piece of suitable negative, I will slip it over the balance display and that will equalise all of the intensities between the four displays. At the moment, the balance display is slightly brighter but as someone has already mentioned, this display is hardly ever switched on.
I now have some single segment failures to do on my BC9000 and with the techniques that I have learned so far, I am confident that I can get a good looking result that restores the full capability of the unit. It is funny how much less satisfying these units are when the displays are faulty – restoring those little lights has somehow made the sound that much better.
Thanks again for everybody’s help, I continue to learn so much from you all.
Regards from
Geoff
