Jandyt:Yes, I believe I have helped carry them.
Corsa back seat goes flat, I still think they will fit with the stands off.
Hi Andy
That's really kind of you - I checked with Peter and he's happy for you to give it a go and try and fit them in your Corsa. I'll drop you a PM to try and sort something out!
Chris - thanks for the offer - I might see how I get on with borrowing Peter's in the short-term just so I can try them out in my living room side by side with my Pentas using the BM8000 to power them. Assuming we can get them up to Leeds, you're welcome to come over and have a listen using a BM8000 if you'd be interested in comparing them :)
