Latest post 06-23-2009 8:26 PM by Dave. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • 06-23-2009 8:26 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: BV8 to DVD player
    Robert:
    I found this on the Beoworld product page for DVD 1, where it states how to change the region code;
    "NOTE: This method does not make the DVD1 Region-FREE. There is a limit of FOUR changes to the product over its lifetime (without professional servicing.) USE THIS INFORMATION AT YOUR OWN RISK.
    Remove any CD or DVD and disconnect the power.
    Press and hold << and >> on the front panel (not the remote) while reconnecting the power plug.
    The current setting shows on the display.
    Use << or >> on the front panel (not the remote) to change Region number.
    Press PLAY to store. Wait 15 seconds until TV screen shows blue."
    Reference: http://www.beoworld.org/faq_view.asp?id=78
    Hope that'll help Mark, when you get a DVD 1.
    Hi all i tried this and nothing came up on screen (i have a MKII dvd1) can anyone help me? I think it is in region 0 mode, but it only plays half the region 4 discs i put through it...
