Latest post 05-07-2007 5:46 PM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 05-07-2007 11:30 AM
    Is the Beo 4 Two Way?
    Hey all,
    Could not find this info quickly enough, so I'm posting it here. Is the Beo 4 a two-way remote (like the BL 5000)? I did not think it was, but wanted to double check.
  • 05-07-2007 11:32 AM In reply to
    Re: Is the Beo 4 Two Way?
  • 05-07-2007 12:16 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    BTW BL5000's are still available new from your dealer. If you want a two way remote.
    CraigBig Smile
  • 05-07-2007 5:17 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The BeoLink 5000 isn't a touch on the Beo4 though if build quality/finish and response time is what you like. The 5000 feels sluggish and cheap in comparison to the Beo4.
    The display is pretty cool though, and the two-way functionality is very very useful...
     Weekly top artists:
  • 05-07-2007 5:46 PM In reply to
    I always thought the 5000 seemed classier than the Beo4. Didn't like the way it worked and it will be slower as it is two way.
    If you are interested in two way, look at the Product Information Guide I have put on the  Beolink 7000 manual area.
