Hello Tim
Speed change could be done operating on the two pushbutton (33-45) OR by a reed relay placed on the lower side of the turntable (The dark side of the TT
To check this reed relay you have to open the unit (The Beo), and control the contact; could be some mech problem or there could be a cap defective, so you have to change it.
It is not so difficult but is better to let a technician check inside, if you are enough skilled to open the unit let me know (I don't know if skilled is the right word so read as " if you normally open a Beocenter 7700 once a week") :)
Let us know,
ciao ciao
