Latest post 03-17-2008 5:58 PM by The Stig - ver. 1.7. 9 replies.
Page 1 of 1 (10 items)
  • 03-17-2008 4:53 AM
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    DVD2, worth considering?
    Hi there
    Now the DVD2 is deemed out, and probably avalible at a discount, is it worth considering as a upgrade over my trusty old VX7000?
    best regards
    Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 03-17-2008 5:03 AM In reply to
    Re: DVD2, worth considering?
    No stay a way from that, and it's not compatible with the LX/MX series.
  • 03-17-2008 5:15 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    Thanks, too bad it is not compatible with the mx. Does anyone know the discount price of the DVD2?
  • 03-17-2008 6:45 AM In reply to
    Plus DVD2 has been discontinued!!
  • 03-17-2008 7:10 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    yes I know. Hence the discount price
  • 03-17-2008 7:18 AM In reply to
    whats the point in buying it, if you can get something much better non B&O which the B&O remote will work with?
  • 03-17-2008 9:14 AM In reply to
    I suppose the rationale would be that it is B&O and therefore integrates better. In this particular case, it doesn't though! The HDR2 would be different as this, although overpriced, is at least designed to work seamlessly. Personally I agree and have a Sky+ box that could easily be part of my B&O system and a Panasonic DVD-R/HDD/Freeview with my other system that although not as good, does offer a similar level of integration, if not better, than the DVD2.
  • 03-17-2008 12:39 PM In reply to
    No matter what the discounted price of the DVD2 will be, I strongly suggest you do not consider purchasing one.
    Regards Keith....
  • 03-17-2008 5:50 PM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Leave it for now. Next will be BR compatiable and much much better.
  • 03-17-2008 5:58 PM In reply to
    I think the Puc controlled BR DVD player's is a better solution, then another re-box.
