Hi @ all
 it was preprogrammed but I must say it was not don the way I was expecting it and it was not done the way it should have been done. I guess there will be so many questions that I have but lets start with 2 maybe easy ones where I could not fand any hints by searching the threds here.
 1. How do I programm TV channels. I do not know the IR commands to put in. I tried hard but never got anywhere. I would be please if someone could give me specific instructions because I do not know anything about XML etc.
2. I have in another room a VX7000 and STB connected. When I access it in the main room I used to push the button on my beo4 e.g. DTV and the thing worked but the sound came out of the front speker of my BV7 (7-40) only so I used the LIST fnktion went to AV and pushed DTV so the stereo signal is carried down to my BV7 and after this I push LIST again and goto SPEAKER and push 3 to have the stereo with the center speaker.
I have tried some workarounds with the beo5 based on the dealer configuration which suggest to go LINK first the V.MEM then Link AV then V.MEM  etc. which I find very complicated and I think there should be another way of doing it.
Howeve to test the Stereo function meaning to reproduce the LIST - AV - V.MEM and LIST - SPEAKER - 3 I tried the following command in the beo5:
under V.MEM -> AV -> Link... -> V.MEM I inserted after the first command done by the dealer two more:
1:000:RADIO:VTR (the RADIO was put in by the dealer?)
1:000:ALL:SOUND (I used the ALL?)
1:000:ALL:CIFFER_3 (I used the ALL?)
 I have all speakers running now but I do not know whether it is just SPEAKER3 or whether it is Stereo plus SPEAKER3 which I want to achieve?
Thanks & regards
Oliver
