Can somebody tell me how to connect HDTV to BeoVision 3 32" MKI with built in HD ready kit and DVI input? Do I need a HDMI to DVI adaptor? How about audio connections for dolby digital etc?
If I connect HDTV signal to DVI input will I be able to change between programmes with Beo4 or how this things are served?
What about other not HDTV programmes will they still work, when HDTV signal is connected to DVI socket?
Thank U for the answers!
