Latest post 03-05-2008 6:29 AM by Eugenio Colazzo. 2 replies.
Page 1 of 1 (3 items)
  • 03-05-2008 4:40 AM
    BEOCENTER 2002 = KNACKERED MMC20S
    Hi, I have  an old BEOCENTER 2002, The MMC20s is now defunct due to 6yr old daughter intervention!,
    I have looked at Ebay and nothing, do I need this one  and only stylus or can I use a different/later/earlier version?
    Anyone know where I can get one from?.
    Thanks in anticipation.
    Pete
  • 03-05-2008 6:10 AM In reply to
    Re: BEOCENTER 2002 = KNACKERED MMC20S
    Any of the MMC20 range will work or indeed the older MMCX000 range. You can get new cartridges from Soundsmith but they are prohibitively expensive!
  • 03-05-2008 6:29 AM In reply to
    Hello
    I found this on ebay 330217069518
    HTH
    ciao ciao
    Eugenio Colazzo
