Latest post 03-05-2008 5:19 PM by Coolskin. 4 replies.
Page 1 of 1 (5 items)
  • 03-05-2008 2:04 PM
    3200 enquiry
    Hi:
    I have been told that it is likely that this is not possible. However, is it feasible to change the HD in one of these to a bigger one? What software issues would there be. Could I not just copy the prerequisite files from the old one to the new one and then put it in?
    Graham
  • 03-05-2008 2:09 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: 3200 enquiry
    Pretty sure this has been covered before Graham, and I seem to remember the answer been it cannot be done.
    CraigSmile
  • 03-05-2008 4:54 PM In reply to
    Re: 3200 enquiry
    Even if you could, you still only can store 99 CD's per color.
  • 03-05-2008 4:56 PM In reply to
    • Craig
    • Posts 4,855
    Re: 3200 enquiry
    Coolskin:
    So not much point in trying to change it then.
    CraigSmile
  • 03-05-2008 5:19 PM In reply to
    Re: 3200 enquiry
    Craig:
    Coolskin:
    CraigSmile
    There is point.
    You can take a HD that makes no, or little noise.
    Our BS3200 (one of the first models) is noisy when switching to the next song.
