Latest post 05-03-2007 11:28 PM by paddy2042. 3 replies.
Page 1 of 1 (4 items)
  • 04-18-2007 8:49 AM
    Serene and Macintosh ical and address book
    The Serene will sync with Outlook express in Windows. Is there a possibility of it syncing with Macintosh ical for the calender and addessbook for contacts?
    paddy2042
    Patrick
  • 05-03-2007 8:07 AM In reply to
    Re: Serene and Macintosh ical and address book
    Is there no Mac user out there with a Serene?
    Patrick
  • 05-03-2007 9:57 AM In reply to
    Yes and it is not possible to sync a Serene through iSync on a Macintosh. This is due to Samsung using some absurb proprietary protocol on their current generation of phones for syncing. This will be rectified with their next set of phones that run an OS based on Linux,but this is of no use to current Serene users.
    The best bet to get contacts from your address book in OSX to the Serene is to copy them into a folder on your desktop and send them over by Bluetooth. If you do not copy them in to the folder as individual files (this is done by holding down the option key when you drag them from addres book to the folder) all the contacts will go into one vCard and not display on the phone. As for your calanders in iCal, there is no work around that I am aware of.
    Nicholas
  • 05-03-2007 11:28 PM In reply to
    That is a real shame as I am more interested in the calendar than the addresses as theey are transferred from my BC60000 when I dock it at home.Thank you very much for the hint about the dumping in folders though - that is a real help. I may try it with a few and ssee how I go.
    Patrick
