This weekend I came across an interesting thing: playing an old Miles Davis album on transparent blue vinyl, on the un-modified 8002, it wouldn't cue but went thru the scan/return cycle like it was "looking" thru the vinyl at the TT, and shut off every time.
Using the 8002 that is using the 8000 processor "can" and 8000 CPU, it played every time!
I've also noticed that the 8002/8000 hybrid glows the sensor arm left arrows every time the arm servo turns while the original 8002 doesn't. Also, if I pause the hybrid, after waiting a while, it parks the arm and shuts down, but if I hit the pause button again, it resumes play where it had been. The 8002 just stays paused until I push another button. And the 8002 will replay multiple times if the play button is pressed after starting play (up to 9X?) The hybrid won't repeat at all (don't 8000s repeat once?) Phil
