Latest post 02-11-2008 2:38 AM by Keith Saunders. 2 replies.
Page 1 of 1 (3 items)
  • 02-10-2008 4:28 PM
    Help needed on set up of 6500
    Have an older 6500 beomaster system and digital speakers.  After moving can't get set up to work correctly.  Is there someone out there that can help? Manual downloaded doesn't show wiring set up well.
    Filed under:
  • 02-10-2008 4:47 PM In reply to
    Re: Help needed on set up of 6500
    I need to know what speakers they are then I can advise on connecting. Also would help to know which 6500 system components you have.
    Regards Graham
  • 02-11-2008 2:38 AM In reply to
    Can you also please say what you mean by "Digital Speakers" do you Powerlink speakers such as Beolab 4500 ?
    Regards Keith....
