Hi All,
it has been awhile since my last post but finally I have finished new house renovation and moved into it, there are plenty of little things to do but I have started connecting B&O.
I have problems with BeoLab 3500 connected with BeoSound 3500 using masterlink via CAT6.
I have connected two masterlink connectors on each end and spliced them using junction boxes to CAT 6 cable using wiring diagram posted here.
Here is Option the setup: BS9000 and BL3500 in two different rooms.
BS9000 Option 1, BL3500 Option 6.
Programming is done when both units in stand by mode.
BS9000: On Beo4 POWER + List -> OPTION -> L.OPT + 1
Confirmation - one blink
Bl35000: On Beo4 POWER + List -> OPTION -> L.OPT + 6
Confirmation - displays "OPTION 6"
However BL3500 displays ": ." and does respond to CD/Radio.. etc functions of the remote.
When I turn volume up - it seems to "wake up" and then shortly goes back to stand by mode.
Before I start checking each wire perhaps I'm missing something? Anything wrong I do in setup?
Is there a way of troubleshooting this?
Thanks you
