Latest post 01-30-2008 5:54 AM by Ericvr6. 5 replies.
Page 1 of 1 (6 items)
  • 01-29-2008 3:39 PM
    • Ericvr6
    • Top 500 Contributor
    • Joined on 04-17-2007
    • The Netherlands
    • Posts 205
    gggrrrr help beoplayer
    Installed beoplayer at the office works after a lot of trubbele
    now bought anew pc at home installed beoplayer but can't register for downloding names and cd pictures.
    want to use my beosound 6
     any surgestions ?????
    gr eric
  • 01-29-2008 3:59 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: gggrrrr help beoplayer
    I had this problem once Eric. I think I resolved it by clicking on the icon on my desktop and I got the option to "repair". After I repaired it asked me to register again. Problem solved.
    BTW, I don't think it likes Vista.
    Andy T.
    Poor me, never win owt!
  • 01-29-2008 4:10 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Eric, I too had the same problem. As once installed the registration screen never came up. Once I unistalled the software and re installed it. It worked perfectly.
    CraigSmile
  • 01-29-2008 5:18 PM In reply to
    • Ericvr6
    • The Netherlands
    • Posts 205
    I installed it five times every time username @ mail adress exists all
    even when I used a other name and @ mail adress
    gr eric
  • 01-29-2008 8:23 PM In reply to
    I have had this problem in the past too. I was advised to install a program called ccleaner. it stands for crap cleaner.
    The program is free and it worked.
    jazz
  • 01-30-2008 5:54 AM In reply to
    • Ericvr6
    • The Netherlands
    • Posts 205
    Dear Mr E,
    Thank you for your email dated 18 January, and we are sorry for this late reply.
    We are pleased to learn that you are the owner of BeoSound 6. If you have already registered your BeoPlayer, you have to use the password and email as usual. As regards the problem with your new PC, pleased be informed that we do not support Vista, if you should be using this.
    Kind regards
    Bang & Olufsen a/s
    Mette Krabbe Helmholt
    BeoCare
    sorry but I use vista what now??? can't use the full options on my beosound 6
