Latest post 01-24-2008 8:15 AM by ajames. 5 replies.
Page 1 of 1 (6 items)
  • 01-23-2008 12:53 PM
    Another Avant Question
    I picked up a masterlink cable today to link my avant into my bs3000 - I've set the avant to link option 2 and the bs3000 to 0 and everything works, apart from the fact that sometimes I want the radio on and to be able to have the picture on the TV whilst I'm waiting for something to come on - but everytime I switch to the radio the avant switches off - any ideas if this is possible or is it because it's acting as the controller.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 01-23-2008 12:55 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Re: Another Avant Question
    press TV - LIST (until the display shows AV)* - GO - RADIO
    *If it doesn't show AV you will have to add it to the list
  • 01-23-2008 4:52 PM In reply to
    It's only AV+Radio no GO Wink
  • 01-23-2008 5:14 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    There have been a number of different versions of the Beo4 Remote control.  If you have an old model, it has an AV button in the middle of the second row from the top.   With this version you do not have to use the list funtion.  Assuming the products are correctly option programmed: Avant Option2. BeoSound3000 Option1 if you have speakers connected to it.  Option 0 if there are no speakers.
    Then simply press AV + Radio.
    The later versions of Beo4 had the DVD button in place of the AV button.  With this version the AV command is accessed via the list function which has to be added if it doesn't already appear.
     Opman
  • 01-24-2008 2:24 AM In reply to
    • UK
    • Posts 970
    The Stig - ver. 1.5:
    Oops, my face is red I stand corrected. Stick out tongue
  • 01-24-2008 8:15 AM In reply to
    Thanks everyone - that was the answer
