Latest post 01-14-2008 1:47 PM by sinuhe. 14 replies.
Page 1 of 1 (15 items)
  • 11-06-2007 1:44 PM
    • Luigi
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Figueres (Spain)
    • Posts 3,013
    BV8, new catalogue
    Pleased, take a look at this picture.
    It seems like this was a new beoplayer for mac osx! Confused
    Do you know anything about this?
    Luis
  • 11-06-2007 1:51 PM In reply to
    Re: BV8, new catalogue
    It could be the PC version running under parallels or vmware fusion??
  • 11-06-2007 2:00 PM In reply to
    It is Beoplayer running in Windows running on a Mac using VMWare in fusion mode (that mixes Windows windows with Mac OS X windows).
    I had it installed in that way for a while. Looks exactly like that.
    p.
  • 11-06-2007 3:25 PM In reply to
    Hello
    How does it work together with a Macbook in PC-mode installed with Windows XP Professional?
    Edde
  • 11-06-2007 3:53 PM In reply to
    You have 3 ways to run Windows on an Intel Mac:
     Bootcamp
    WMWare fusion http://www.vmware.com/products/fusion/features.html
    Parallel
    With bootcamp you've got to reboot your mac into a PC mode
    With the 2 others you can start a virtual PC like you start a program on your mac.
    You can run the PC inside a window on the Mac or can activate a mode that mixes Mac and PC windows. VMWare is better at doing this.
    Mac run PC software very fast. Even in virtualisation mode. Actually the fastest laptop under windows is the MacBook Pro...
    p.
  • 11-07-2007 5:01 AM In reply to
    • Luigi
    • Figueres (Spain)
    • Posts 3,013
    Excellent!
    Do you know which TV tunercards are supported by beoport-mac with VMWare?
    Luis
  • 11-07-2007 5:06 AM In reply to
    It is Beoport PC that is running, there is no Mac version.
     Except for the Mac Pro, you cannot install an internal Tuner card in a Mac.
    If a USB Tuner works with Beoport, it is very likely it would work in VMWare as well.
     p.
  • 11-07-2007 5:12 AM In reply to
    • Luigi
    • Figueres (Spain)
    • Posts 3,013
    Ok.
    The question is if a USB Tuner would work. At the moment, only tv tuner pci works.
    Thank you.
    Luis
  • 11-07-2007 5:23 AM In reply to
    For people with a Mac, you can use a software called BM-Link instead of Beoport, it has some restrictions, but it also has some advantages.
    It only works as a server (Option 6 or 4), you cannot listen/view to main room sources from the Mac.
    But... it uses iTunes music and radio library and play all music that itunes can play.
    Beo4 controlling works as with the PC version (using color buttons, etc...)
    It sends artist names, album names, etc... for display on the main system.
    It can control Frontrow locally if you add an IR eye.
    It is not fully working in Leopard, the latest operating system that was just released, but i am sure a fix fill come soon.
    p.
  • 01-13-2008 3:25 PM In reply to
    Do you know if it works with Leopard by now?
  • 01-13-2008 3:26 PM In reply to
     do you know if it can handle Leopard by now?
  • 01-13-2008 5:11 PM In reply to
    not completely :-(
  • 01-13-2008 7:55 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    actually i could have sworn that i read in the specs of the new serenata that they have made the software to work with mac now... am i wrong?
  • 01-14-2008 4:26 AM In reply to
    It is in the specs but not released yet, I read a while ago.
    But I also read that without software you can already place music and download photos on the serenata, from your mac.
    p.
  • 01-14-2008 1:47 PM In reply to
    Öhm,
    if I use Beoport in my PC (which actually is a Mac but running Windows by Paralles, for example), can I still use iTunes for playing my music, or does Window version require using B&O's software? If Leopard version is not up and running, this would be the only way to go, but useless if one wants to stick with iTunes???
