Hi All
Can anyone advise if replacement tone arms are available for Beocentre 7007 ? Either a complete unit or just the arm, as my inquisitive daughter has just snapped off the headshell.....luckily i had removed the cartridge only moments before.
The Cassette deck has also stopped playing. The motor turns when unloaded but will not play the cassette.
Lastly, are there any recommended UK repairers for older B&O?
Thanks in advance.
Regards
Jan
