Latest post 01-05-2008 10:17 AM by Santiago. 5 replies.
Page 1 of 1 (6 items)
  • 01-04-2008 5:09 AM
    • Klas
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Singapore
    • Posts 96
    Beoport and BL3 - how can i make the Beoport MK3 compatible?
    Greetings all - decided to exchange my BL4000 and connect my BL'3s to my computer; however i get the well known buzzing sound when connecting the 3's and thats by using a MK3 cable- i have one of the absolute first versions of Beoport - so assume it only have the 5dins solded..........
    Anybody know how to get this fixed? Easy to do myself or can the Beo-service shop do it or the local electrician?
    Cheers
    Klas
    Grant me the serenity to accept the B&O I can't afford
  • 01-05-2008 3:41 AM In reply to
    Re: Beoport and BL3 - how can i make the Beoport MK3 compatible?
    Hello Klas,
    I had the same problem some months ago when connecting my BL3s to my very old BeolinkPC2 (beoport), and this is what I made by myself:
    weld pins 7 and 2 together
    Santiago
  • 01-05-2008 3:43 AM In reply to
    Result: BL3s completely stop buzzing after this bypass:
    Santiago
  • 01-05-2008 3:57 AM In reply to
    • Klas
    • Singapore
    • Posts 96
    this is excellent Santiago; appreciated - i assume that pin 2 & 7 are connected with a piece of wire/solding?? Will get the solding iron up tonight and start working on my first "bypass" :)
  • 01-05-2008 5:35 AM In reply to
    • Klas
    • Singapore
    • Posts 96
    Bypass SUCESFULL and patient survived and had a quick recovery; its working a charm!! thanks Santiago - it was a quick 30min job with your excellent instructions
    Cheers
    Klas
  • 01-05-2008 10:17 AM In reply to
    Hello Klas,
    I´m really happy for your success ! Yes -  thumbs up
    Now, enjoy a lot with such a fantastic audio equipment Smile
    Best regards.
    Santiago
