So it was as I thought... thanks a lot!
I just wanted to be sure, otherwise I would have been too nervous about it..
The setup is in a small room that there won't be need to got that much sound. And yes, most likely I would hear the distortion before anything would blow up.
The S75 speakers are really good, I got mine for about 40 euros some half year ago and I've been very satisfied with them. I just two weeks ago replaced the caps and that made it even better. Mine are also rosewood covered, they were a bit worn out but I have grinded the surface and oiled them so they really look great. I also got the medal stands (those were a bit rusty-fixed now). And the BC1400 is also rosewooden, as good-looking as the speakers.
Bang & Olufsen - The art of controlling sound, picture and light
