Latest post 12-22-2007 8:40 AM by Turbo. 4 replies.
Page 1 of 1 (5 items)
  • 10-22-2007 6:10 PM
    Beogram CD 7000
    Im sad today, i have had my Beogram CD 7000 in for repairs at my B&O store but it come down to that the fault is the laser and since B&O dont have them in stock, they cant repair it. So right now i have to settle with a CD-player that is very moody, sometimes it plays as its supposed to but most of the times it "skips" (sounds like it fastforwarding, sort of and then "find" a spot where it can start play again).
    Now for my question, is really the only alternative for me to find a "new" Beogram CD 7000, there is no way for me to get a replacement-laser somewhere else? And if that is possible would anybody be able to install it? Me personally have very limited knowledge of "hacking" inside audio-stuff. I have a Beogram CD 5500 but i will probobly die if i where to destroy that one just to rip its heart (laser) out.
    Regards
    MoglesMac
    Sweden
  • 10-23-2007 3:07 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Beogram CD 7000
    Perhaps Ulf (Ulf Kiener) can help you out.
    He has done a lot of repairs, including CD 6500 for example.
  • 10-23-2007 6:24 PM In reply to
    Re: Beogram CD 7000
    Thanx for the tip :D Will get it back next week probobly and will see how "bad" it still is, but i guess i will try to get hold of a "new" Beogram CD 7000.
    Cheers
    MoglesMac
    Sweden
  • 10-26-2007 12:56 AM In reply to
    • Ulf
    • Top 100 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 665
    Re: Beogram CD 7000
    In most cases, it is not the laser but a small capacitor.
    On the small circuit board, where the drive is connected, there is a
    capacitor, sign as 2103,  33uF 16V.
    Replace it.
    Eventually, the drive still be harmonized.
    Focus and laserpower.
    My CD7000 reads at now CDR-W's
    Ulf
  • 12-22-2007 8:40 AM In reply to
    • Turbo
    • Not Ranked
    • Joined on 04-18-2007
    • Sundsvall Sweden
    • Posts 67
    Re: Beogram CD 7000
    Is it okey to use a capacitor with a higher voltage marking? I am not sure what the capacitor do in this circuit but it often okey to use higher voltage markings in some applications. This one seems to be a little difficult to find...
    Jens Larsson Engine development engineer
