I have a Beosound 9000 hung vertically. When using my new Beo 5 remote on the Select Disc option the 9000 stopped playing its current disc but did not move to the selected one. After a few minutes the 9000 switched itself off and the cd clamper dropped to the bottom!! After a few seconds it started to climb in small movements back to the top position. I tried the same options again with the same results - though this time I was ready and lowered the clamper to the bottom. It works perfectly with my old Beo 4. Any ideas anyone - other than using my Beo 5 as a very expensive paperweight?
