Latest post 01-05-2009 3:43 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 01-05-2009 2:35 PM
    • beodim
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Switzerland
    • Posts 130
    Help: How to connect Beocenter 9500 to Beocenter 6?
    Hi everyone,
    I have an opportunity to buy a Beocenter 9500 and would like to connect it to my Beocenter 6-26 as a temporary solution until I get the dedicated speakers. How can I connect the BC 9500 so that I can hear the CD/tape output from BC 9500 through the speakers of BC 6-26? Looking at the connections scheme in the BC 9500 manual I can't really see any audio output socket.
    Thanks in advance for advice!
    BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
  • 01-05-2009 3:03 PM In reply to
    Re: Help: How to connect Beocenter 9500 to Beocenter 6?
    I suggest that you need a Beolink converter. You can then use this to connect the Masterlink socket on the Beocenter 6 with the AUX socket on the 9500.
    Regards Graham
  • 01-05-2009 3:05 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    You will need a Beolink converter, to go between the two. Had the same setup with my old Beocenter 9000 connected to my BV3-32. You connect a Datalink cable from the Aux of the 9500 to the converter and a Masterlink cable from the converter to the Beocenter 6.
    CraigSmile
  • 01-05-2009 3:24 PM In reply to
    • beodim
    • Switzerland
    • Posts 130
    Many thanks for the quick feedback! So, does the AUX socket of BC 9500 work both as input and output (I thought it was the sound input only)?
  • 01-05-2009 3:43 PM In reply to
    The AUX is input and output.
    This is a pretty standard config. The same connection system works with, say, the AUX on a BC2300 and Masterlink socket on the Avant. Works fine if you can't afford dedicated active speakers.
    Regards Graham
