Latest post 12-19-2007 4:59 PM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 12-13-2007 3:58 PM
    • BeoMatt
    • Not Ranked
    • Joined on 12-13-2007
    • Norwich
    • Posts 51
    Beomaster 1900 help needed humming
    Hi everyone, I have just aquired a Beomaster 1900. All seems ok apart from a continuous hum  o(Just like feedback) in all selections, Phono/Tape/Tuner. this hum increases on the Tuner and obviously when increasing bass. Can anyone advise on a soloution, I am technically minded.
  • 12-13-2007 4:29 PM In reply to
    Re: Beomaster 1900 help needed humming
    Could be capacitors in the power supply. They do deteriorate with age.
    Regards Graham
  • 12-13-2007 4:41 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Welcome to Beoworld !  Yes -  thumbs up
    I agree with Graham, definitely a capacitor problem and there's a lot of caps in there.
    Grab a capacitor kit and replace the lot.
  • 12-19-2007 4:46 PM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Cheers guys any suggestions where I should aquire a kit ?Confused
  • 12-19-2007 4:59 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    You should be able to get one from Martin (Dillen). Who does several Cap Kits.
    CarigSmile
