Hi guy,
I was wondering if you please could help me regarding my decision with a B&O setup. Ordered a pair of BL8002(new BL8000) for my BV8-40 because I was dissapointed regarding the sound of the 8-40. I also own the "old" BS2300 with a pair of BL2500.
Because I also would like to use the BL8002 with the BS2300, I`m not quite sure if it make sence.
1st option: use the TV and sound system not linked. So I`m not able to benefit of the BL8002 if listening BS2300
BV8-40->BL8000
BS2300->BL2500
2nd option: use the TV and "old" BS2300/BL2500 sound system linked.
BL8000->BV8-40->Masterlink->Converter1611->AUX-connection->BS2300/BL2500
3rd option: use the TV an "old" BS2300" without BL2500
4th option: change the "old" BS2300/BL2500 for a BS3000/3200 without speakers
BL8000->BV8-40->Datalink->BS3200
I will place the BL8002 left/right of the BV8-40 (please take a look at the picture).
Because I do not want to chance the system within the next year, I would like to install the "right" system from the start.
Thank you very much for your suggestion.
BeoVision 8-40, ATV2, BeoSound 4, Front BeoLab 9, Rear Beolab 4000 MKII, Beo 4
