Latest post 12-14-2007 7:24 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 12-14-2007 6:55 AM
    Beovison Avant connection to beosound 9000
    Hi just wanted to double check, is the best way to connect these two products using the mastlink connections
  • 12-14-2007 7:24 AM In reply to
    Re: Beovison Avant connection to beosound 9000
    Yes, You should connect them with a Masterlink cable.
    Regards Keith....
