Latest post 12-05-2007 1:48 AM by turbotol. 3 replies.
Page 1 of 1 (4 items)
  • 12-04-2007 11:11 AM
    • his722
    • Not Ranked
    • Joined on 12-04-2007
    • Posts 2
    HELP - Receiver recommendation??
    I bought BeoLab 8000 and BeoLab 3 so far. but i couldnt afford to buy BeoSystem 3. too expansive!!!
    I am trying to buy a good receiver for my home theater.
    Would you please recommend a best receiver between $1,000 and $2,000?
    Thank you.
  • 12-04-2007 11:57 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: HELP - Receiver recommendation??
    Well you could buy a second hand B&O television with a built in Dolby surround module. Other than that yo may find that $2000 will not buy you a great deal. You have over $12000 worth of speakers so skimping on the source may not be the best idea.
    We got a BV3_32 with DSS for a measly $2200... However we don't utilise the DSS yet as we only have 1 pair of Beolabs.
  • 12-05-2007 1:45 AM In reply to
    Rather depends where you are. If in the US, then a B&O TV is rather out as there will not be any cheap old ones! I would suggest that this may not be the best forum to get information on other makes.
  • 12-05-2007 1:48 AM In reply to
    how about a used beosystem 1?
