I am not sure, that I understand you correctly, but have you connected both powerlink, masterlink and a beolink eye to the MCL/ML.
If so, you must remove one or two connections.
Connect powerlink only, if you want the ML/MCL to work as a amp. that is always on, when the main system is on.
Connect masterlink and a beolink eye, if you want local control in a link room.
Hope this helps.
Christian
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
