thorne:I have the mark ii and unless you are looking at the screen full-on, the picture is washed out. Is the mark iii any better or is this a basic fault in LCD TVs?
Due to the way LCd is manufactured none of them handle off axis viewing very well. You willhave to wait for Sharp mid next year to come up with a panel that due to its modified array will allow greater angles.
Not for nothing does B&O have avery good motorised stand so you can get it just right!
