Latest post 12-02-2007 2:09 PM by Medogsfat. 5 replies.
Page 1 of 1 (6 items)
  • 12-01-2007 8:21 AM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Replacement drivers for CX100
    I am looking to replace my drivers in one pair of CX100's, I do not want to refoam them. If I buy them from B&O will they now be Butyl? Roughly how much are the replacements from B&O? My other alternative is Recone Labs which I used for my RL140's. I cant justify the cost for CX100's although Recone did a fantastic job.
    Kind regards
    Dave
    Beowulf
  • 12-01-2007 8:31 AM In reply to
    Re: Replacement drivers for CX100
    Replacements are about £30 each from B&O if I remember correctly. Its well worth it though as you then have a pair of speakers that will last you years.
  • 12-01-2007 8:55 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Are they Butyl or still foam surrounds? Thanks for the speedy reply!
    Beowulf
  • 12-01-2007 9:14 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Still foam.
    Chris.
  • 12-02-2007 1:11 PM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Hi Chris, I bought some CX50's off you a while back which you had refoamed, what do you think to the kits, is it reasonably straight forward?
    Kind regards
    Dave
    Beowulf
  • 12-02-2007 2:09 PM In reply to
    • Medogsfat
    • Posts 4,045
    Hi Dave,
                the kits I have used are fine. It isn't perfectly straightforward as the centering is critical otherwise the coils will rub and sound horrible and eventually wear out. If you decide to go down the refoaming route then drop me a PM and I'll advise you if needs be.
    Jandyt did an excellent step by step thread in the workbench section here on refoaming some S120's.
    Chris
