Latest post 12-01-2007 2:43 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 11-30-2007 3:22 PM
    Dolby avant?
    When I turn my avant on a Dolby symbol appears in the LCD panel. Does this mean I have the board fitted?
    What does this mean? Does it output a prologic signal or will it allow processing via an external amp? Would this help me to determine the age of the system also?
    Graham
  • 11-30-2007 5:01 PM In reply to
    Re: Dolby avant?
    Probably - but check the label at the back - it will tell you! What connections do you have? How many speaker outlets? It produces Pro-Logic in the earlier versions. The last ones can produce DTS.
  • 12-01-2007 1:42 PM In reply to
    Re: Dolby avant?
    Hi:
    It has one masterlink and six dins on the back. Does that help? It also has a (c) relating to Dolby on the silver s/n sticker.
    Graham
  • 12-01-2007 2:43 PM In reply to
    Re: Dolby avant?
    Sounds as though you have Dolby then! On the label though there should be a section with ACC and some letters after it. Mine has STB DS PIP on it. This means STB controller, Dolby Surround and Picture in Picture modules are fitted. I actually have a DTS module as well but this is on another sticker as it was added later.
    Yours may have either DS or more likely AC3
