Hi,I have recently purchased a BEOMIC 2000 from Bang & Olufsen. But I don't know how to solder the connector. The mic came with the original connector unsoldered, a standard guitar connector with only two terminations. But as you can see on the picture the cable has two cords and a shield. Does anyone know how to solder them? Can I connect an XLR to the cable? It's a ribbon mic.Thanks!
Looking at the top diagram (Audio Aux Link). You should have pins where 1, 2 and 3 are located.
Craig
Thanks for your reply!
No, the connection wasn't a DIN, it was a 3,5 mm jack plug. I will try to solder a standard XLR connector. Shield to pin 1, red "hot" to pin 2, black "cold" to pin 3.
I hope it works!
