Doc:Can the DVDplayer of the BV7 be opened by remote (Beo4/5)?
I have thought this would be a useful option for my DVD1 (via Beo4) but on reflection why? If you require the tray to be opened/closed surely you must have either just placed a disc in or want to remove it. In both cases you will be in front of the unit and able to press 'eject' with your finger!
One annoying thing however with the DVD1 button layout is that having placed a disc in the open tray, the tray then masks the 'play' button so a finger has to go under the tray to the 'play' button or 'eject' has to be pressed thereby closing the tray and revealing the 'play' button.
If B&O are so good at design, why is this?
Finally. why label the 'eject' button with the word 'eject' when it closes the tray also! Why not 'open/close' ?
