Well it was advertised as beotalk 1500, when up for private sale. But same as you, I wondered if it was a 1401 ? from the booklet it says the following; Beotalk forms together with a Beocom 1400 or 1500 a combined phone and answering machine. So from that I gather it could be a beotalk 1500. Basicly I think it looks like the  beotalk 1400 ( the difference is probably in the telephone horn. )
Do you know if its supposed to a double plug ? one on the other ,...same as when you want to use an extra phone on the same wall socket ?
I looked for an adapter and from what I read in the booklet it should be 4,5 wat. I have tried it for it was a variable adapter but no lights or what so ever seem to turn on.
Anybody has an adapter still hanging around for a Beotalk 1401 ,or as I am to believe for a Beotalk 1500 ?
 I`ll put down some facts from the phone itself:
Beotalk
B&O 1006729
S/W 2.2
Serial no.:1006729  95160004 94W42
Also is it possible to order those base rubberoid pads ?
