Latest post 11-22-2007 9:30 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 11-22-2007 8:41 AM
    • bwaje
    • Not Ranked
    • Joined on 11-22-2007
    • Paris - France
    • Posts 38
    beogram 1200
    Sorry for cross posting, I discovered this sub forum after posting in parents' forums;
    my question is simple : is the belt for beogram 1200 flat or round ?
    thanks
    b&otien
    Filed under:
  • 11-22-2007 8:50 AM In reply to
    Re: beogram 1200
    I believe is is round. B&O did actually make some a while ago but they will have gone by now. I know some people use large O rings cut to the correct size if you cannot get one.
  • 11-22-2007 9:27 AM In reply to
    • bwaje
    • Not Ranked
    • Paris - France
    • Posts 38
    Re: beogram 1200
    Thanks Peter, but what is a "O Ring" ?
    b&otien
  • 11-22-2007 9:30 AM In reply to
    Re: beogram 1200
    Rubber ring often used as an oil seal in automotive parts. Can be cut and then superglued to the correct size.
