Latest post 11-21-2007 5:03 AM by akeret. 2 replies.
Page 1 of 1 (3 items)
  • 11-19-2007 6:54 AM
    • akeret
    • Not Ranked
    • Joined on 10-14-2007
    • Posts 3
    Best resolution for BV 3-32
    Hi all
    What is the best resolution to set on a mac mini for connecting to a BV 3-32?
    I tried all the standard resolutions (800x600, 1024x 768) but I guess there are better settings.
    Any ideas?
    Filed under:
  • 11-19-2007 1:21 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Best resolution for BV 3-32
    800 x 640 would be the best. Anything higher and you won't see a thing! Anything lower and there will be no display space! Are you using the Mac as a media centre?
     Weekly top artists:
  • 11-21-2007 5:03 AM In reply to
    • akeret
    • Not Ranked
    • Posts 3
    Thx,
    yes I am using the mac mini as media centre.
