Latest post 11-11-2007 11:45 AM by Alex. 4 replies.
Page 1 of 1 (5 items)
  • 11-11-2007 4:06 AM
    • gofer
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 27
    ipod connection to BL8000
    I am looking to use my ipod as my bedroom system through BL8000 therefore any advice appreciated on the simplest and most direct route to connect the two. Has sanyone done something similar?
    G
  • 11-11-2007 8:10 AM In reply to
    Re: ipod connection to BL8000
    I would assume just use 2 single rca audio cable, one for each speaker and connect them to a 3.5 mm stereo plug and plug it into your ipod.
    You can get 2 rca to stereo connector cable easily at any electronic store.
    Hope this helps
  • 11-11-2007 9:27 AM In reply to
    What is the system in your bedroom? It is probably easier to attach the iPod via a dock to the Aux input on the system rather than having wires to the speakers. The above suggestion is the simplest if you have nothing else in the room though.
  • 11-11-2007 10:17 AM In reply to
    • gofer
    • Not Ranked
    • Posts 27
    Nothing else in the room at the moment, but may add a BS4 later.
    Anyone connected the ipod directly? Interested to hear what the view on SQ is.
  • 11-11-2007 11:45 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The sound will be good, but obviously not as good as CD. The iPods can actually sound very good as long as you use high bitrates, preferably in AAC format or Apple Lossless format (although the latter takes up stupid amounts of space).
    One thing I would recommend is an in-line volume control, you can get them from Maplins for £3.99. Unplugging my BeoLab 4s from my laptop produces a pretty darn loud pop, but this in-line volume control did away with this issue.
     Weekly top artists:
