Hi everybody! I've been lurking/mooching for quite some time in anticipation of owning some B&O products. That time has finally come! A local guy was able to set me up with a set of the Beovox 5000 and a Beogram 2000 table.
I don't have a Beosound to hook the turntable to, just an old AR integrated amp and a Quad phono pre. Since the phono stage takes RCA (& XLR) inputs, I'm at a bit of a loss on how to connect the two. I'm assuming that there are adaptors out there, but I don't think I'm looking in the right places or asking the right questions. I can build the RCAs myself if need be, but in order to do that, I need a pinout diagram. From what I've read, the 6th and 7th pins (far right and far left) on the DIN plug are removable, that leaves me with 5 pins.
What goes where? I'll apologize in advance, as I'm sure it's been covered a thousand times before, but my searching mojo is not up to par recently.
Thank you-
Shawn
