Latest post 10-29-2007 5:14 PM by Jandyt. 4 replies.
Page 1 of 1 (5 items)
  • 10-29-2007 3:48 PM
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Beomaster 7000 and Beo4
    I'm not really familiar with this old set. Can I store stations with a Beo4?
    If yes: how?
  • 10-29-2007 4:56 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beomaster 7000 and Beo4
    Yes Gerd but it is a bit complicated.
    You have to trick the Beo4 into thinking it's tuning the TV.
    I'll get back to you in a few minutes with the details.
    Andy T.
    Poor me, never win owt!
  • 10-29-2007 5:02 PM In reply to
    • Jandyt
    • Posts 13,004
    Right, here goes-----
    1   Add V.SETUP to your list
    2   Press Radio
    3   Leave the room and press TV and then list until V.SETUP appears
    4   Press GO, it should then say TUNE
    5   Return to the room were your Beomaster 7000 is
    6   Press up or down til you get the fequency you're looking for
    7   Press list until STORE appears
    8   Press GO  17  Go (presuming you want to store your new station as 17
    Bit long-winded, but it worksGeeked
    Hope this helps.
    Andy T.
  • 10-29-2007 5:08 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    Wow, very tricky! Will try that ...
    Thanks!
    Gerd
  • 10-29-2007 5:14 PM In reply to
    • Jandyt
    • Posts 13,004
    My next quest will be to find out how to do it with Beo5Erm
    Andy T.
