Hi, has anyone any idea what the difference is between the original deflection board for the T8111 and the board which is placed (labelled S-flat) when the tube is replaced (for an S-flat type) ?
I have both versions but i only see some difference in values of some capacitors, is this all ?
If anyone has the diagram of this S-flat deflection board that would help also (i already have the original).
Thanks.
