Latest post 10-22-2007 5:35 PM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 10-22-2007 11:02 AM
    Beocenter 7002 turntable arm
    Hello everybody
    I need to dismount the turntable arm of a Beo 7002, I need your opinion reguarding the test of conductors; I want to check the corrispondence using a tester but is this correct or there could be the risk to damage (burn) the conductors?
    Thanks a lot
    Eugenio
    Eugenio Colazzo
  • 10-22-2007 5:35 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 7002 turntable arm
    Eugenio,
    A normal ohm-meter will be fine. It won't burn the thin cables.
