I own a Beovision 3-32 type 8800 on a non motorstand; now I've bought myself an almost new motorbase[plate] type T4067 for a non roller-table, but when I tried to put the TV on top of it to attach it to the TV with 4 srews it doesn't fit properly, so I stopped trying.
Does anyone know if there are perhaps different kind of motor bases for a BV3-32 other than a T4067 and what the difference is, or should I just push harder and let it fit by the use of [some] force?
thnx
